QUOTE (gspot @ Sep 16 2006, 06:56 AM)
Just installed a set of Broston Pro 60s with driver in the kicks and tweets on the doors on axis. Problem is they sound way too harsh, even after setting -4DB in the crossover. I've had a set of SL60s before and loved the sound. The main difference would be that the SLs used a silk tweeter and the pros are metal tweeters.
Would like suggestions on if its installation location (may try the tweeters in the kicks).
Also, if i was to look for other tweeters, which ones? maybe a set of SL60 tweeters? wouldn't mind some feed back on some morels.
from my personal experiences, I have tended to find that harshness is generally a characteristic of a speaker, moreso then it's settings.
A harsh speaker imo will always sound harsh. If you attenuate it, then it will just sound like you have harsh speakers with no treble and imo will not smooth out the sound at all.
This is at least what I have found from experiementing in the past.
Sadly, I'm not sure if there is much that you can do. Mounting them down low off axis may reduce harshness somewhat, but will also greatly sacrifice detail.
Attenuating the tweeters too much will make your sound lack in the top end, while retaining it's harshness.
This is my opinion, so i'll give some others a chance to state theirs
Although adjusting crossover points / amplifier gains could potentially improve things
