I'll demontrate how this is done
First, you need a piece of glass (Obviously)
You need to block ot the areas that you DON'T want etched. Vinyl stickers are a great way of doing this. The other option is to use either Masking tape or contact adhesive and cut your own pattern out.
So add the sticker to your glass.
To etch the glass there are 2 ways, you can buy etching solution, which is a liquid that will etch the glass, however I have found this quite hard to come by.
So I use a sand blaster
Put the glass and sticker in the cabinet
And blast away!
Try to keep the nozzle at 90 degrees to the glass. If the angle becomes to great, it can blast the sticker off.
Doing large areas takes time. As long as the sand is flowing properly, just nice slow left to right strokes is fine
Keep going until all the surface is evenly covered. Hopefully you should end up with something like this
Yes, I know it's a bit rought and not even in some parts. But it was just to demo
In most cases, this probably isn't the desired effect. So what you need to do is get the inverse of the Logo made up. Then you'll get this effect
Trying to show the light didn't quite work
So there you go. Add a few LED's around the edge or backlight for some nice effects.
Big thanks to MRS. TEK for providing both stickers.
