QUOTE (kaniff @ Oct 19 2006, 09:06 PM)
Ok so when i bi-wire them how do i set that up?
I bridge the two second channels for the woofer and just use channel 1 for the tweeters? or should i bridge 1 AND 2?
How will that change RCA setup and input channel?
Also, i have no idea how to tune bi-amped setup. I used a tuning guide from this forum but im not sure if it had anything on Bi-Amp tuning. Could someone please link me this?
]Cheers for the hand guys, i'm pumped about getting the most out of these speakers..
Your Crossovers have a switch in them, for bi wire or normal.
In order to bi wire, you need to set that switch to bi wire.
then, on your amplifier, plug both the RCA's into the 1+2 Channel, set the amplifier to accept signal from 1+2 only, to spread to the 3+4 channels also.
IE: so you input 1+2 and it outputs on all 4 channels.
Next connect the rear channels to the Midbass input on your Z6 Crossover, and the Front channels to the Tweeter/High input on your Z6 crossover.
it's very simple to work out if you just look at them.
This will give you the opportunity to tweek the Volumes of the Midbass/tweeter by tuning the gains up/down on the amp IE: front is tweeters, rear is midbass.
This would be the optimal setting IMO.
The amp is stable to 2 ohm in stereo, so you running at 3 ohm, you'll be getting well more than your claimed 125W per channel. Dynamically the Z6 can handle masses of power, but realistically you would never require or reach the said high power rating of this speaker and 100W RMS should be more than enough, unless these speakers are horrifically inefficent.
If your amp cannot be set to accept 1 pair of inputs, to output all 4 channels, you will need to get some RCA Splitters.
An interesting thing to consider with your Boston Z6's, regardless that they cost $2000 RRP here,
at the end of the day, they are only $500 USD Speakers, Designed to compete with Alpine Flagship DD Linears, Focal K2p, DLS Ultimates ect. So they should be expected to perform in the 1k AUD range here, not the 2K range!! A quick look at there build quality, specifications and design puts them in this lower range also.
Juls
