woogzter
Oct 22 2006, 05:33 PM
Hey,
Where is the best place to go to get 6"/150mm 90 degree PVC bends.
I went into bunnings and the largest they had was 4".
Any help would be much appreciated.
SPL_Lancer
Oct 22 2006, 05:42 PM
Try a plumming supply store?
Woob
Oct 22 2006, 10:10 PM
any decent sized bunnings will have it
Oct 22 2006, 11:04 PM
QUOTE (SPL_Lancer @ Oct 22 2006, 05:42 PM)
plumBing
but any big bunning, any irrigation supplies shop, or any plumbing place should stock it
Charger
Oct 23 2006, 12:19 AM
QUOTE (trism @ Oct 22 2006, 09:04 PM)
plumBing
I hate to sound rude, but why post if what you're saying has already been brought up in this thread? You're just repeating what's already been said.
Oct 23 2006, 12:30 AM
beacuse i wanted to be a smartarse and post what everyone else was thinking...why be so bitter???
AttitudeAudio
Oct 23 2006, 09:36 AM
I remember a tutorial a while ago that mentioned it is possible to bend the PVC to suit your application using a heat gun and sand.
Memory going soft here, but apparently...
cap one end of the pipe, fill it with sand, and then heat (carefully) the area you want to bend, and slowly bend it manually.
The sand was used to keep the shape to allow the same surface area internally, and not just kink it.
The heating method should be the same as for flaring the end of the pipe too.
Anyone else remember this method?
