Falc
Oct 29 2006, 11:51 AM
I have finished sound deadening my two front doors and the boot and have deadening left over. I thought about doing the firewall but after pulling the carpet out yesterday I found there is massive amounts of deadening from the factory anyway so it wouldnt be worth it. I current have the roof lining out of the car so I can deaden the roof, is this worthwhile? I also noticed that the bracing in the roof is hollow, is it worth filling with expandable foam, this is what I did to the boot frame.
The car is an EA fairmont Ghia, I havent done the rear doors, should I bother?
Jnr
Oct 29 2006, 02:13 PM
roof is always good. it made u huge difference on pigphama's au wagon but he actually lost db from it though
Falc
Oct 29 2006, 02:16 PM
can you describe the huge differance? less outside noise or more response for certain frequencies?
What about expandable foam in the roof cavities?
DaBaSSy1
Oct 29 2006, 06:01 PM
I'd be interested to know too
I'll be setting up system/car soonish and am considering sound proofing just about every panel on the inside of the car ie, doors, roof, floor and boot. Hope I don't warp the roof
Actually, that'd be pretty cool.....
Falc
Oct 29 2006, 07:25 PM
I've decided to sound deaden the roof, and I have taken the velour off the roof lining and started to fiberglass the roof lining (it's thick card that has the open cell foam and velour stuck to it), I will then roll 3mm closed cell foam onto the roof lining and glue the velour back onto the closed cell foam. I am also going to fill the cavities in the roof with expandable foam to cut down wind noise. Hopefully it will cut down most outside noise
Oct 29 2006, 08:23 PM
do it....ive always believed that its bad for spl, but for daily driving/sq, DOOOO EEEEET
RoVer™
Oct 29 2006, 08:35 PM
My guess is it will reduce wind noise on high speeds dramatically, especially in an EA.
But I can't really think of how sound deadening the roof will improve SQ?...
