Ok, so far I have an ok system, however it is far from perfect. Basically I’m running the supremo set 6 of a soundstream Van Gogh 4 channel amplifier, with the crossover points used on the amplifier. At the moment the signal comes from an old clarion DRX 9255 which is very limited to say the least, with only bass treble and fade adjustments. Basically I want something that can do two way active with more adjustments plus sub. Sub fade controls is more important rather than cross over points as this is done via the adjustment module on the VRx and I am happy with this arrangement as generally all I do with this is fade the sub or bring it more into the spectrum. I am more set and forget in this respect, however I could be satisfied with simple fade controls on the hu as I do at present.
If I were to keep the factory hu, what options would you take? Would you add in something like an external processor from this and control it from there being fed from an LLC, just go something such as a JL 360 etc? Or take a totally different path all together such as simply a HX-D2/9655E and mod the dash to accommodate it. At present the hu is not accessable easily and this is an issue for me when driving and I am not keen at present to mod the dash. I am aware that there are dash kits available for the mk2 focus, however I do not want to adjust the aesthetics of the dash at all as this is the centerpiece and would draw too much attention. As in something like a 30 band EQ, processor? I know in another thread Henry mentioned that BSS etc, however I am not familiar with this brand.
Can you list reasons of what you would do, and specifically the equipment. I know that Ram in Vic is doing something but I am not sure of what that is. Also I should point out that space is slightly limited as there is a Ti12d Elite in the boot, and if you know this then you know that the box and the motor structure is huge. I have enough space for a soft bag either side of the motor.
Cheers,
Anthony
