Is there a way of setting gains of a 4 channel amp with a multimeter? I want to acheive EXACTLY the same gain for each side after i have bridged it into 2 channels.
I thought testing the voltage of each speaker terminal using a test tone would work but i get very different results from each of the 2 bridged channels.
Also when i test the speaker terminal voltage one speaker terminal reads negative voltage when i have read test lead on + and black test lead on - , does this mean my amp has a polarity isssue?
What tests can be done with a multimeter with respect to car audio? (bridged amp gains?, voltage drop etc)
And in particular what tests can be done to help SQ?
