Full Version: 6-7" SQ Midbass
Iceman_jkh
Hey kids,
Just looking for some ideas for a 6"-7" midbass driver.
Driver will be installed into a very deadened door of a VY commodore.
Requirements:
*Good Low end extension (hoping for something down to 30-40Hz area)
*Fast attack/punchy/powerful midbass kick
*Excellent SQ for 30-300Hz
Currently thinking about: Morel Supremo, Oz Audio Elite Mids, Boston Pro and ImageDynamics 8", but would definitely like to hear others' opinions.
Peace
Ice
TEGBOY
You have heard my RF woofers in my doors, what did you think of them??
Luke352
My vote is for the Boston Pro's I've only heard them on a demo board but I can say I initially thought the sub was still on and had to check.
Iceman_jkh
I must do that next meet, regardless if I'm still looking for woofers.
Luk> Cheers. I agree.. Ive heard them on a board too, and they are quite 'strong'.
Ben
X2 on the RF woofers... I dunno what their Xmax is, but damn! they look the goods when they get pumpin!!!
I'd like to say that my Z6's are good at pumping bass, but alas they aren't that low in the extension range... unless you set the EQ to SQ2, Which lowers their WRMS, and I still doubt they would get down to a useable 30 hz, but they do give you a nasty snap to the chest (80-300hz range, especially with acoustic snare hits) when they get moving. Having said that, I have to inject them with around 300WRMS each to get them to do it..
muzzy66
How much space do you have?
I know a driver that would fullfil your every need, but as a result it's bloody big.
Rainbow W175 Power - i.e. the midbass unit I'm currently running. Here is a link:
http://car.rainbow-audio.de/products/intro...pro=1&lin=5
These play low, and hit hard. They are also from a two way SQ component set, so I can guarantee you they will play smoothly and detailed well beyond 400hz.
Only downside, is i'm not 100% sure of how much they cost, of if they are available as a seperate driver (or only as a set) - oh and of coruse the depth issue.
Your best bet would be to contact a local Rainbow dealer (if there is one) and go from there.
When I tested the woofers in my cars once, I had the crossover running at 65hz or so. I lowered it to the lowest possible (around 50hz) and they just kept doing down, down, down.
I disabled the crossover entirely and ran them full range, and the difference was immediately noticable, so I can confirm they definately play down to 50hz and below with no trouble at all. How far below I haven't been able to measure, but I will comment more when my installation is complete and they are properly insttalled and set up.
Personally, i'd be very surprised of there is much out under 8" there that can compare. In fact, it wouldn't surprise me if to hear these out play some larger 8" and 9" midbass drivers - they really do have a LOT of balls.
Iceman_jkh
Muzzy> Cheers... I had thought about that... might have to look into it a little more. Have you heard that driver compared to any of the others on my list? Can you compare?
Space wise, I used to have a 93mm driver in there.. so its gonna come very close!
Luke352
If you go onto the DLS website they have what they call the RW6 sub kit comes with two 6.5" subs admittadely they would need an enclosure but only about 8-9litres which shouldn't be excessively hard to do in your door. Should work as a great midbass I'd think, maybe email the guys at DLS over in Sweden apparently there great to deal with.
Here's what they say about it:
The RW6 subwoofer kit comes with two 6,5" drivers, a 3" , 24 cm long, bass port and instructions for building an enclosure. The recommened enclosure for these drivers is only 18 liter so it can easily fit into any vehicle. Recommendations for other enclosure types is also included. Combined with a suitable amplifier this box creates a controlled and deep bass sound, more than enough for most bass lovers.
Speaker type : Subwoofer kit with 2x 6,5" woofers and 3" bass port
Impedance : 4 ohm
Woofer size : 6,5" (16,5 cm)
Power handling : 100 W RMS / 200 W max
Frequency range : 30-4000 Hz
Sensitivity : 87 dB (1W/1m)
Magnet size : 110 mm (4,33")
Outer diameter : 165 mm (6,5")
Installation depth : 84 mm ( 3,3")
Mounting hole : 140 mm (5,5")
Weight : 2 kg (4,6 lb
Parameters: Qts: 0,45 Fs: 47 Hz Vas: 12,2 l (0,43 cuft)
Recommended vented box : Volume 18 litres. Port: 3" diameter, 20 cm long
Owners manual in PDF : Click on the picture to open high res image in new window
The attached manual is in Swede I assume, but you can understand the basics.
~Spyne~
the oz's are great mid-bass speakers, but i really dont know if they are capable of giving anything 'special' much below 40hz. it could just be me being too scared to pump them with the hpf set that low, but there are few 6.5" speakers i would be happy to run that low...
DD W6.5LT and rainbow power would be two, and possibly the boston pro.
Iceman_jkh
Spyne> have u heard the DD's? I wouldnt be suprised that they go loud & low, but do they also sound nice?
The rainbow will be added to my shortlist.
SCorpion
im probably going to have my rainbow power's installed (properly) by around the christmas time i guess.
if u wanted a listen, im sure a i can make a trip to melbourne to give u a gander.
Iceman_jkh
Thanks... if I havent already got some mids I'll definitely take a listen.
well ice i just took 5 hours of my time to drive over to phatt to deliver my run in OZ mids for sam to try in your car.. (ok well it was a 3 hour round trip driving!)
hope you enjoy and like.
Iceman_jkh
heh.. thanks rob.
I cant wait to hear urs, the brand new ones we tried sounded crap.. amazing what a little 'burn-in' time can do.
QUOTE (Iceman_jkh @ Nov 18 2006, 02:32 AM) *
heh.. thanks rob.
moved out here for my new job.. sucks! wonder if there is anyone on here from whittlesea?
i put the new ones in my car, there not to bad but need a bit of time.
i also hear you have no sub, did you hear my car with the sub turned off? makes a huge difference!
QUOTE (Iceman_jkh @ Nov 17 2006, 10:05 PM) *
The W6.5 is a derivitive of the 6.5 that Jassa started making over 20 years ago for the studio monitors that got his company started.
They have been tweaked and tweaked over two decades, I love them.
Brad at Car Tunez just got his 6.5LTs in. He was impressing everyone at the shop yesterday by playing 20Hz sweeps through the front doors. smile.gif
TEGBOY
Holy McFvking hell, I love those doors.
Iceman_jkh
Phil> Do they NEED to be in enclosures to sound good?
I have my doors heavily deadened and the service holes are sealed, but there are still some air leaks (window gap, drain holes, locking rod opening etc).
Enclosures are not an option for me unfortunately.
mosoto
http://www.hybrid-audio.com/
QUOTE (TEGBOY @ Nov 18 2006, 08:50 AM) *
Brad does nice work.
fury
Without turning this into ANOTHER DD thread,
Is there anywhere in Melbourne where these woofers can be auditioned?
muzzy66
Very sexy looking install there so far Phil, much credit to the person responsible smile.gif
QUOTE (muzzy66 @ Nov 18 2006, 11:26 PM) *
Brad - Cartunez.
Iceman_jkh
Phil> Do they need to be in enclosures to sound good?
How well do they go playing into the door cavity...no box.
PHD
for that DD mid bass driver, do they need to run with passive crossover or run it active? Phil, do they come with crossover?
sqgator
Dare I say Dyn MW172. I am waiting to install one pair soon. Looks good on paper. The only catch, it's an 8" driver....mod your car for it!!!
Fs: 45Hz
Sd: 180 cm**2
Recom freq range: 35 - 3500 Hz
Linear excursion (p-p): 9mm
Power Handling: 150W
Powerband
Click to view attachment
I'm putting that in my porn collection!
Hey ppl on the topic of midbass drivers what are the Image Dynamics CX-62 like?
Woops, I just realised the ID was listed in the original question
mmm...no-ones had any opinions of them so far
Does that mean anything?
phil, anymore pics of the LTs???the DD website doesnt have any.....
micka
I have rainbow powerline splits in my car at the moment; I could probably organise time for a listen if you're interested:)
Shreknos
the id's dont get a mention cos they aint the flavour of the month,,,
it will take for someone to buy a set, get them too sound good, and start a fan club befrore anyone recognises them...
Woob
QUOTE (sqgator @ Nov 19 2006, 01:55 PM) *
Fs: 45Hz
Sd: 180 cm**2
he's selling his Elate 9's to go with smaller drivers BECAUSE he doesnt want to modify smile.gif
Iceman_jkh
Exactly.
As Woob said, I already have Elate 9"s, which sound fantastic in a box and I would love to put them in the doors, but they just wont fit without a serious hackjob. sad.gif
Poisoner
vy commo? bah thats old enough to hack apart. if u had a VE it'd be a diff story. tongue.gif
Iceman_jkh
Id need to hack metal to get it to work properly. And I dont like that idea.
Leviathan
Ice as a matter of interest is there a big difference between the 6 and the 9 ?
Have you heard them ?
zion187reigneth
QUOTE (-Charlie- @ Nov 21 2006, 03:57 PM) *
LOL , but true
Ice what about german technology http://www.mbquart.com/en/produkte/car/
ultim8DTM5
Not sure how "German" MBQuart are anymore, or who owns them now for that matter? (RFCorp not trading well)
muzzy66
Just to give you an idea of the size of the Rainbow driver, here is an image.
The second speaker is a 6.5" Response coaxial from Jaycar, which from memory has a mounting depth of around 75mm.
Gives an indication of the relative depth and diameter of the Rainbow in comparison to an average 6.5" mid-bass driver. May given an indication of the type of work involved in getting one in smile.gif
Biggest issue for me was actually my windown windows not providing sufficient clearance, so installing the drivers required abit of modification.
QUOTE (zion187reigneth @ Nov 21 2006, 11:22 AM) *
Luke352
What about some DLS Midbass drivers there are lots to choose from. The DLS to me, tend to have quite a thick sound to them in the midbass department, bass quitar, and double basses etc blend amazingly with my IDQ, but this is where the IDQ really shines aswell. Plus nearly all there drivers are under 65mm in mounting depth and also not very wide at the back thanks to the NEO magnets.
