The results however are extremely rewarding
What you will need -
Consumables:
- 2.4m * 1.2m of 18mm MDF ($63)
- 2 Tubes of liquid nails ($8)
- 100 36mm to 45mm chipboard screws ($7)
- 10 Hours of your precious Saturday
- Speaker Wire ($5)
- Two 10" Subwoofers (sony penatagons in this case $75 each)
Non Consumables:
- Two saw horses
- Jigsaw (that allows you to adjust the angle of the cut)
- Table Saw
- Pencil
- Tape measure
- L ruler
- Drill with assorted bits
SAFETY GEAR IS A MUST.
When cutting mdf, both GOGGLES and A GOOD FACE MASK/RESPIRATOR are CRITICAL for your health and saftey.
Link to the Decware Plans
The woofer is a Sony XS-L101P5 350wrms 4 ohm single VC - any pair of 10" subs will do really. The box can be made to sound better for particular subs by playing with the volume in the sealed section.
Click to view attachment
Now that we've read the plans and have all our equipment, let's get to it.
First step is to follow the instuction in the Decware link, it goes through a step by step guide as to where to draw the lines for your horn, which will be where the mdf walls go later on. You end up with this:
My first thought when I did this was: "Bloody brilliant, that really narrows down where the walls are supposed to go."
To make it easier for you, Voila.
And to make it easier later on (read when it comes to screwing the top on) I suggest you lay your top board on top of your bottom and transpose, AS ACCURATELY AS POSSIBLE, the lines where the walls are going to go - this may take 10 minutes extra here but it will save you a good hour when it comes to screwing the top down!
Now we know where to put all our walls, let's get building.
Be careful to make sure that the walls are at an exact 90 degree angle as this will impact upon the sound of the box. If they are not at 90 degrees it will have completely defeated the purpose of the lines you've transposed onto the top of the box.
I decided to use fibreglass for more strength throughout the structure, this is however not of fundamental importance.
When using higher excursion woofers (woofers that will move more air) I would suggest angle cutting (or flaring) the horn opening to get rid of any unwanted noise (ie chuffing) that may occur.
The design highly recommends using a double baffle.
Sides and Back on
Note to self: Put the wires onto the terminals before you put the sides and back on, as on one of the woofers the terminals are on the bottom, so I had to use a mirror and stuff around to get the wire into the terminals.
Want some music while you're installing? Just rig up a battery charger, battery, amp, iPod and you're laughing. Haha, this was more to break in the woofers a bit........ actually I'm not really sure why I did it, it is by no means necessary.
Now note the strips of 3mm closed cell foam cut up into strips that have been in the last couple of pictures.
These are to seal the top of the box.
The single design flaw of this box is that if you screw and glue the top then you are unable to access your woofers - they could die and you would have to rip your box up to replace them!
The closed cell foam acts as a gasket and also allows for small variations in height differences between the walls. If you have large variations, about 2-3mm, then I suggest using a thicker closed cell foam or even better sand them so that they are all as close as possible to one another.
Apply contact adhesive to the top of the walls and stick on the closed cell foam, I used a dynamat roller to get any air bubbles out.
Screw the lid on and put it in your car. Damn I hope you measured up your car before you started building the box
Wire it to your amp and away you go, enjoy
Complete listening evaluation to follow but for now just let me say the SQ and SPL are brilliant - for cheap, crap subs this box makes them sound absolutely incredible. So far in terms of SQ I would put it on par if not slightly better than my DD9115c and Alpine Type X. It gets very low, is extremely accurate as well as quick, true to the recording and loud!
Cheers,
Lindsay.
