All you need, is;
A soldering iron(Im using a 40w one, standard tip) - Jaycar Electronics - $12.95
Solder - 60:40 tin:led - Jaycar Electronics - $1.65
OFC Shielded single core cable(WB1508) - Jaycar Electronics - $2.25/m
RCA High Quality Ends - Jaycar Electronics - $3.50ea(per plug)
Wire Crimpers/Cutters/Pliers
Stanley Knife
Electrical Tape/Heatshrink.
Click to view attachment
Alright. now... onto the work.
1) a) First thing is first, pull the plug apart.
b)Then measure up the cable against the "inside" plug.
2) Remove the outer housing with a stanley knife, just above the crimp section of the plug. Continue to remove the copper shield and the aluminium shield with the knife, but not the plastic core.
3) remove, using the knife, a small(.5~1.5cm) section of the white plastic from the tip of the core. BE CAREFUL NOT TO CUT STRANDS OF THE CORE. the more strands in the core, the better quality signal.
4) Now, line the cable up with the plug, and remove a section of outer housing slightly(1~2mm) larger than the "crimp" section of the plug.
5) Now whip out the soldering iron and solder and go town on the two connection points. make sure that the core is NOT connected to ANY PART of the shield, or the rest of the RCA plug, or you've ruined it. NOTE: it looks like i used way too much solder with this one, but i didnt. it just looks bad. it doesnt matter though, because you dont see it. it doesnt need to be pretty, it needs to be strong. as long as the core and shield arent connected, use a fair bit of solder.
6) Wrap a loop of electrical tap around the connector, not too tight, but snugly.
7) the final product:
NB: Its useful to slide the housing onto the cable prior to soldering...
also, remember to use the same coloured plugs on each end of one cable...
i think that's it for now. will add more if i realise i forgot something.
enjoy and good luck
-alex
PS: one thing i have found, these cables dont like to be bent too sharply near the connections. they tend to snap away at the core... this can be overcome by extending the core and giving it some slack, but i simply didnt bend them. someone else may have more info on overcoming that one
