My goal with this project is to do a stealth install into my car. I want it to look exactly the same at the end of the project.
Everybody seems to have the same story of molestering the original speaker pods to a point where there just not going to hold the weight anymore. This speaker weight was my main concern in the design of my pods (each speaker ~2.2kg).
So Basically my first step was to get an original speaker pod a trace the base outline onto 3mm MDF.
I originly followed the angled speaker tutorial because I belived I would not have to fibreglass, but in the end I did. Heres the tutorial:
Speaker spacer tut
I cut one normal ring out of 6mm MDF and used a planer and sander to angle two rings out of the same 6mm MDF. So far each pod now consists of a base 3mm, one 6mm ring and two angled 6mm rings. (The height and angle of the design is entirley up to you and your speakers, thats why i cant be much more specific).
Like i said I was not going to fibre glass but i was concerned about the weight. That is why I have ran long bolts through the pods and simply cut them to length on the other side. (The bolts arent centred or spaced in any way because the rings were slightly out of alignemt to fit the base. You can see this down at the bottom of the ring. They simply didnt fit quite how i thought they would which is why it is important to do many test fits).
This picture shows the base shape (traced from the original pod) and the bolts i ran through the pod for support as well as my miss alignment:
Basically once i knew how the speaker fitted in the door I ran the screws through the pod and then liquid nailed all the rings and the base together.
I then did a test fit with my trim back on only to find that i needed to remove some of the top of the pod because the trim didnt fit. (it didnt fit because the pod was slightly miss aligned to fit the speaker properly). The speaker didnt fit properly initialy because the magnet was so big.
This picture shows a a black line at the top of the pod where I had to trim it. (The pod was trimmed before it was glued to the base. I used a drop saw to trim the pod.). You can see the top of the speaker is flush with the pod while the pod hangs out around the rest of the speaker. It also demostrates a test fit:
I found an old fibreglassing kit in the garage and thought "why not". Certainly was not going to hurt.
You can see the angle and the fibreglassing job:
All that was left to do was a bit of paint and foam gasket. (foam is self adhesive from clark rubber). Not shown is the foam gasket i used between the speaker and the pod.
And thats about it!!
To finish off I sound deadened:
At the moment I'm in the testing phase buts its sounding very good!
Im yet to finish sound deadening properly, atm its just the dynamat over the holes, will cut out MDF later.
I was worried about half way through that i was going overboard but im happy with the end result, peace of mind is priceless.
Some interesting problems i ran into:
The actual speaker needed to be mounted in the door so that the original trim could fit back on. However, the magnet on the speaker is so big that it did not fit through the hole in the door. This involved me having to cut the flange of the door to mount the speaker in (i used a rotary tool and cutting disks). You can also see I siliconed some rubber on there to make mounting the speaker easier and to prevent rust.
Another problem is at the moment with the trim on there is no more then a 1mm gap between the speaker grill (holding the speaker in) and the speaker grill on the door trim. You may say " why not push the speaker further in to the door?". Well this was why:
Its quit tight! (picture taken from inside the door, thats the magnet.
And one last picture just out of interest heres my stealth tweeter install:
The demister grille fits back on, just.
Anybody who nows what there talking about please feel free to correct. This is my first go at anything like this. Its been a big learning curve and ive learnt heaps from my mistakes.
Currently im battling with noise in the system when the engines running, I notice that it gets particularly bad when the air conditioner is on. Once i fix this my system will be finished (till i get a sub
Hope you guys who requested it find it useful. Please ask any questions in the forums so others may learn, no pms, thx guys.
