Full Version: DD9515
HIDCBL
I have an E-audio 300D
Am getting a DD 9515f hopefully
Either D0.5 or D1 ohm's
Which one should i get.
Website says the sub is rated for 3000rms...
So, if i get D0.5 and run it at 1ohm then it will get 3000rms
Or i can get the D1 and run it at 0.5ohm and get ~6000rms???
Which one should i get?
HISPL
If you think you will get 6kw out of an E Audio then you need to put the crack pipe down... tongue.gif
I would reccomend goind with the dual 0.5ohm model, then look for another E audio you can use for comps and run one per coil you might get 4kw out of each e audio if you are lucky wink.gif
HIDCBL
Lol
Thanks buddy.
Most people go 0.25ohm for comp use on those amps.
You could get a dual 0.5 ohm 9515, run 1 ohm for daily and 0.25 for burps.
bscimia
i would go for dual .5's, for spl anyway,
dual 1 is good, if you want a slightly more sq and want to run at 2 ohm, less distortion etc for daily,
but for pure numbers get .5's
bscimia
