Full Version: Ford Futura EF speaker install
Rocket
Hi Guys,
This is my first post on this forum and i'm hoping to obtain some information i can use to upgrade my speaker system in my vehicle. I currently have six inch speakers mounted in the front doors and it appears that there may be tweeters mounted somewhere in the dash. I have narrowed down my new speaker to a focal 160 v2 speaker which will fit the rather shallow door to enable proper fitting.
I think the focals will drop straight into the door without any modifications to the trim but i have noticed that part of the speaker will be hidden once the door is closed. It looks like that door had a lack of space and the speaker is placed close to the front dash and obscures part of the speaker cone.
I haven't had any experience installing speakers, except about 20 years ago in my old holden.
Has anyone had any experience installing new speakers in a ford futura? What did you do apart from installing 6 inch replacement speakers in the door? Do you think a pod could be installed as an alternative?
Any advice is great appreciated.
Regards
Rod
data_mine
You could bother with a pod, but the dash doesn't really block all that much cone area. (I used to have an EL). And yeah you will have some tweeters in the dash.
Rocket
QUOTE (data_mine @ Jan 15 2007, 06:54 PM) *
Hi,
Thanks for the advice. On closer look i agree that the speaker isn't that obscured by the dash and it
will suffice. I am looking at also installing 8inch focal v1's in the rear shelf. I have an lpg tank and i need to
obtain 8 inch pods about 4cm in height. Any ideas where i can source them from in australia?
Regards
Rod
RoVer™
Have a look in JB Hifi, I know they have the 6x9's and 6" pods, unsure if they have the 8" though.
Considered building the pods yourself?...
