Full Version: ported box
mac_man_luke
Hey
im just planning my ported box for my 306C
I planned to use 2x 110mm ports but when i use that they are hugely long
if i use 1 x 110mm port it is acceptably long - do you think that would be enough?
its a 2-2.2cf box
thanx
mac_man_luke
nudge
20Hurtz
aim to have the port length below 500mm so which ever diameter that is 500~800 will still shouldn't have any chuffing. Why not go with a slot port 300mm*30mm is under 500mm in lenght? Sorry i am at work and don't have my bass box so i cna't be to accurate.
mac_man_luke
slot ports just so much more work to build and they dont look that good, but is an option
if i go any smaller than about 100mm WinISD says there will be port noise and 110 is still on the boundary (and about 600mm long)
mark_sudakov
to tune to 30Hz, use a 100mm diameter pipe, 40cm long
to tune to 35Hz, use same diameter, 27cm long
mac_man_luke
so one 4" port will be enough? cool
just thought i might get noise
mark_sudakov
not sure if u will have issues with noise, i didnt. But to tune to 35Hz with 2 4" ports, length needs to be 60cm each.
mac_man_luke
35Hz seams to high for me
i was planning 28-30
mark_sudakov
QUOTE (mac_man_luke @ Jan 18 2007, 10:07 PM) *
to tune to 30Hz with 2 4" ports, length needs to be something like 85cm long each
mac_man_luke
yea, so ill prolly just go with 1 and see how i go
20Hurtz
for daily listening you do'nt need to tune that low for the 306 ~33 is good.
