QUOTE (Pulse-R @ Jan 22 2007, 09:57 PM)
I'm interested to see the results of this.
whilst playing a test tone, you want to measure the voltage out of the speaker terminals, and the current in the speaker wire (on AC).
Power (Watts) = Volts AC X Current Amps.
so 48V x 45A = 2160 Watts RMS.
If your meter is not True RMS, then reduce the calculated power by about 5% to get the RMS value.
another way to measure the current, if you don't have a clamp meter, is to put a 0.1 ohm resistor (marked 0R1 on it) in series with the speaker. This would want to be at least 20Watt resistor. then the measured voltage on the resistor = 1/10th of the amps, so 4.8V = 48Amps.
5%????
