Full Version: Vh commodore head unit troubles
Mobile Electronics Australia > Mobile Electronics Discussion > Beginners Discussion
Young Gun22
I have a Vh commodore and I have just bought a head unit for it I was wondering if anyone could give me some help as to get the old one out. Someone said that I have might have to take the dash off to get anywhere. If anyone could get any info this would be great.
Dual Mono
Need more info
Does it have the original unit in there or is it aftermarket, if so what brand/model
57REO
yeh u have to take the dash off mate, im currently doing up a vh and i took it all apart to take the stock H/U out and repaint the dash. have fun lol
Hissey
there is an easy way to get the stock HU out, but it requires a screwdriver and a hammer, and you just bash straight through the center of the unit till you can get to the back and unbolt it, just make sure you have power disconnected before you try this
proaudio
there are special keys that allow you to get the stock unit out, but it is very hard to get them. Or remove the lower left dash panel.
QUOTE (proaudio @ Feb 1 2007, 08:27 PM) *
Not that easy.....
There is a bracket at the back of the unit that is bolted in from the top.
You need to drop the lower half of the dash off, this means pulling the glove box and A/C controls out.
Even then you need to cut through the bolt that holds the rear of the stock unit in.
jk_matt
Huh, every VH i have owned (two) and the countless VH/Vks i have worked on, merely required you undo the nuts behind the volume and tuning knobs
That said they only had the AM radio in them
By looking quickly at some stuff i have laying around, pull the ash tray out and see if that helps any
pulling the dash out isnt very hard anyway, just be careful with the heater controls
wagonay
Cleutin
QUOTE (DD Phil @ Feb 2 2007, 06:43 AM) *
Aint that the truth lol
i did a VL for the 1st time on Saturday... factory deck was murder to get out but got there after a while. once its out, the wiring was a 10min job tongue.gif
wagonay
if vh decks are anything like a vl deck it would be mountains of fun, that said i can do a vl deck in under an hour now
