Can anyone confirm for me whether a CDRW-DVD drive from an IBM T42 will fit and work with an IBM T60 (my laptop)? I think the 2 options are below. They seem to be the same (i.e. dimensions etc.), just wanted to double check cos i can't test before buying (2nd hand).
Or will both work?
Hoping one of you IT guys can help me out
Thanks in advance
Ultra bay slim drive (with flat bezel)
Get two drives in one with this high-speed, high-capacity read/write storage solution. The ThinkPad CD-RW/DVD-ROM Combo Ultrabay Slim Drive (with Flat Bezel) combines all of the advantages of a DVD-ROM, CD-RW and CD-ROM into a single drive by allowing you to read DVD and CD media and create custom data CD's. This versatile optical drive is recommended for usage in the media bay found in the ThinkPad T60 and Z60t Series notebooks, the X6 Ultrabase, the X6 Ultrabase Tablet, and the ThinkPad Advanced Dock. Although this drive can be used in the media bay of the ThinkPad R60 Series and Z60m Series notebooks, the equivalent function 73P3275 ThinkPad CD-RW/DVD-ROM Combo Ultrabay Enhanced Drive is recommended for better fit. (Note: For the ThinkPad Z60m notebook we recommend the ThinkPad CD-RW/DVD-ROM Combo Ultrabay Enhanced Drive.)
Weight & dimensions
Depth 129 mm
Height 9.5 mm
Weight 0.185 Kg
Width 128 mm
Weight & dimensions
Depth 129 mm
Height 9.5 mm
Weight 0.185 Kg
Width 128 mm
and
Get two drives in one with this high-speed, high-capacity read/write storage solution. The ThinkPad CD-RW/DVD-ROM Combo II Ultrabay Slim Drive helps you store and use data, audio CDs and play DVD movies. A versatile optical drive for the ThinkPad X4 UltraBase Dock, and ThinkPad T40/R50 Series notebooks and can also be can be used in ThinkPad notebooks and docks that have Ultrabay Plus or Ultrabay 2000 modular bays by adding the optional ThinkPad Slim Drive Adapter for Ultrabay 2000.
Weight & dimensions
Depth 129 mm
Height 9.5 mm
Weight 0.21 Kg
Width 128 mm
Weight & dimensions
Depth 129 mm
Height 9.5 mm
Weight 0.21 Kg
Width 128 mm
- Stooge007 out
