QUOTE (mazda626 @ Feb 9 2007, 08:34 PM)
yeh i was actually thinking of doing an electrical apprenticeship, but i dont really wanan work my ass off for 4 years straight for crap all pay. or move to WA lol
im more interested in the construction of circuits, and designing pwoer stations and relays and all that sort of stuff..
There is another option - a traineeship which is between an apprenticeship and an engineering degree where you do an advanced diploma at a TAFE. Such as this one in Vic
Advanced DiplomaUsually you would do the traineeship with one of the electricty companies eg Country Energy in NSW where there is a mixture of school and on the job training.
I did a similar course several years ago with the SEC in Vic and ended up as a Senior Protection & Control Tester. From your comments above, this role sounds like what interests you. Basically you take the draftsmans drawings and the Protection Engineer's relay setting files and then test and commission the protection schemes. This involves loading the setting files into a relay via a laptop and then testing that the relay inputs and outputs operate correctly individually, and as part of its protection scheme. It is a fairly challenging role where there is a lot of problem solving and a lot of variation in the day to day work
The sort of jobs I have been involved with are things such as Testing and Commissioning
- a new 66 / 22 kV Zone Substation (includes 66kV Lines, Transformers, 22 Feeders etc )
- 66kV Line Protection Schemes
- 66 / 22 kV Transformers
- 22 kV Feeders
- 22 kV Co Generation Plants
- New Equipment at HV Customers Installations such as ESSO BHP etc
I have now progressed into SCADA (Supervisory Control And Data Acquisition ) this may also be a field of interest to you. This is basically where remote stations are monitored for alarms and metering data and controls can be sent remotely. For example you would have a control room somewhere is Sydney that is monitoring numerous suburban zone substations and can see the AC currents and MW loadings on the lines while checking for alarms and possibly opening a high voltage circuit breaker if required. This is more of an I.T. based role and is also very interesting and challenging
