Full Version: Ribbon midrange
_Anthony_
I just basically what to know what are the benefits of using a ribbon mid range over say a 5 inch mid range driver. How is off axis response, espescially if it were mounted in the kicks?
Say with a set like the Hertz, it already has a 6 inch mid, however this is not a dedicated mid bass. How do conventional 6.5's such as the hertz function as a dedicated mid bass? Are there usually any compramises with using a high quality 6?
Say with the Supremo set 6, adding a 5 inch or ribbon, how would you expect the 6 to perform with either the Hertz ribbon or a 5 inch supremo?
zion187reigneth
you could fasten these to your doors tongue.gif ........cors
http://www.apogeeacoustics.com/specialprojects.html
_Anthony_
Somehow the apogees might be a little hard to fit into the car...biggrin.gif
So are they basically electrostats? Do they have the same limitations?
My thoughts are: to get a ribbon mid small enough to fit in a car properly, they wouldn't play low enough to be any more useful than a good tweeter.
Ive always wondered why a midrange ribbon myself. Tweeters is understandable. Hertz ribbon for the mille set plays 700Hz to 35kHz. You cant convince me thats a midrange...
It is understandable for tweeters though. Ribbons have such a unique sound to them...
RMA
QUOTE (The Tick @ Mar 14 2007, 09:54 PM) *
There are a number of mids available for both Morel and Hertz
In the Morel range the factory recommended mid for Supremo 5 or Supremo 6 is the CDM-88 there is no factory three way crossover at this stage for SUPREMO they are recommended to be run active.
In the Hertz ranges MILLE - the ML-500-R ribbon mid. Hi Energy the MD500 and HL70
Hertz have a range of three way crossovers available. $146 for the Hi Energy up to $1249 for the Mille.
_Anthony_
So phil the CDM-88 is what you recommend as a mid range for the supremo? I'm aware that the supremo set 6 is run active, I actually have a set wink.gif Atm I'm just toying with the idea of 3-way active and wondering what combinations would work, not that I have the cash at the moment to go that way... rolleyes.gif Just considering options for the future.
In regards to the hertz, I was wondering what benefit the ribbon adds to the hertz set if it is supposed to be a mid range yet as the Matt says it freq resp was 700hz upward. Seems it will be performing a lot of the mid range and it will be crossing with the tweets.
Additionally, although not worded that well initially, I was wondering if there are usually compramises when using say a usual 6 as a dedicated mid bass instead of reaching up into the higher frequencies.
RMA
QUOTE (The Tick @ Mar 15 2007, 05:55 PM) *
The Morel factory I have spoke with at length on this matter, they recommend the CDM-88 as a mid, they claim it has more authority than the CDM 54.
When I get the time to do it, my car will be running Supremo 6 with the addition of the CDM 88.
Whilst I hear thematt's concerns regarding the extended range of the mid it must be remembered that the mid was designed to run with the MLK 3 system and that it has a specific crossover to run with and that is exactly what they were looking for when building that system.
TRD1JeeZy
QUOTE (thematt @ Mar 14 2007, 09:41 PM) *
was flicking thru an indonesian car audio mag yesterday at audioart and there was a home loudspeaker ribbon...looked like your average smallish active subbox for home theatre but with a big ribbon down the front. it also was CES 07 winner...
Poisoner
i want electrostaics or what ever they are called. shame they are so delicate and cant be put in a car.
fury
QUOTE (POI.ZNR @ Mar 16 2007, 10:14 AM) *
Got a spare quarter mil?
http://www.criticalmassaudio.com/electrostats.html
the CDM88 does look (from specs) to be much nicer than the 54.. I never really like the CDM54's lower-mid sound.
Might be worth a look at some point.
_Anthony_
Quad Electrostats are much more affordable, but they can't be played too loudly. Would be very good coupled with a sub for moderate listening levels and I think do tend to break up easily.
QUOTE (RMA @ Mar 16 2007, 07:22 AM) *
Ive seen the response of the CDM88, and it does look very nice indeed. Certainly better then the Dyn Ive got now...
What I dont understand Phil, is if that midrange goes from 700 to 35kHz, why would you need a tweeter at all?? Yet the MLK3 has the tweeter too, which in itself can drop to 900-odd Hertz. Thats just overlapping. Surely if you were going to create a driver and mate it to the crossover, you'd be specific in its frequency response and deny it the ability for too much overlap??
If I was building an "entire" interior from bare metal, then would use something nicer, but really you need to get the acoustics right to take advantage of anything "Audiophile".
