Ok, so you want to design a Transmition line enclosure for your sub. But it all seems a bit to complicated for you. Well guess what, it is actually quite simple. The majority of websites will tell you that a T-line’s in a car is just to large, well there kind of right if your using a 15” driver with a low Fs. But there are a few shortcuts we can use to make a T-line for a car not much bigger than a large ported box.
Ok, so now we need to get to it. To select a driver for your T-line is quite simple. The ideal driver for a T-line has a Qts of .40 and lower, and Qms of 7 and lower. Now for the Hard core math’s involved in designing a T-line. T-lines are based on the speed of sound, and the length of the sound wave. Now, sound travels at 344.424m (1130ft) per second. Now our T-line is “tuned” to a quarter length of the sound wave of our Drivers Fs. To find this all we do is divide 344.424 (1130ft)/Fs (lets say or driver is a Type R so the Fs would be 27Hz) witch equals 12.765m. This is the full length of a 27Hz sound wave. Like I said before we need to find a quarter length of out 27Hz sound wave, so all we need to do is divide 12.765 by 4. So 12.765/4 = 3.189m. Now you might still think that this is pretty long considering that a true T-line is just that a line/port that’s area is equal to Sd (cone area), or fairly close to it.
In our case the Sd of a Type R 12” is 467.59 cm^2. So our T-line is 3.189m long with a port area of xxcm^2. Now cause this is going to be in a car environment we don’t have to be so exact with the measurements, we can round the length and the area, for this example I am going to round the length to 3200mm and the area to 467.59cm^2.
Now we need to get our port dimensions down for this T-line i'm going to use a port height of 140mm and a port width of 330mm and the length as stated above of 3200mm. Now you might be saying that this is still way to big to fit in the boot of your car. But, just like a conventional port in a ported enclosure, we can fold our T-line. This is where just like designing a regular enclosure you need to figure out the maximum dimensions of the area in your boot you are (can) sacrifice for your enclosure. For this particular enclosure I have the maximum dimensions of 1040mm x 400mm x 500mm. for this T’ line we will need to have 3 folds to fit it in out space. (Note I am not using the boot of my car for this, it is actually going in my house). The line will look something like the crappy paint drawing below with the folds.
Click to view attachment
Note the thin black line this represents the center of out T’ line. This is where we measure the length of the line from when folding it. I put the 45 degree pieces of MDF in the corners of the port to try and keep it the same width all the way thru, and to also help direct the air flow smoother. Now you also might have come to realize that you might not always be able to make the port deep enough to accommodate the mounting depth of the driver you are using. To make up for this you can either mount the driver inverted (Note: if doing this you need to reverse the phase of the driver (Swap the positive and negative wires around)), or make a mounting baffle up similar to if you were mounting deep speakers in your doors.
From here it is just a case of building the enclosure just like you would with a normal enclosure. At this stage I haven’t built the enclosure as yet. When I do I will post build pics of it in this thread, for now you will just have to settle for some 3D drawings.
Now for more SPL use you can take a shortcut of sorts with the length of your T-line by tuning it to the Bass boost on your HU or amp. For example say that your amp has a boost at 40Hz you can turn this on and make your line to this instead of your drivers Fs. You might think that the Driver will not play as low, but if you are using a driver with a Q of around .30 or lower you will be surprised with how low the driver will play when taking into account cabin gain etc.
I know that I haven’t covered EVERYTHING involving T-lines like Tapering etc, but this tutorial is aimed at a basic intro to designing Quarter wave transmition line enclosures.
Edit: Also posted on OzA. http://www.ozaudiophiles.com/forums/index.php?showtopic=51
