QUOTE (20Hurtz @ May 23 2007, 02:01 PM)
this will be run full actively from my v12 amps (545 and 345).
QUOTE (20Hurtz @ May 25 2007, 05:14 PM)
the only tuning tool i have atm is my 9853R (two way + sub TA, 5 band parametric and crossover)
Lindsay, you (will) have almost the same setup as me.
I have 3 way front active (6.5", 4" and 1" ) running actively off my 9835 and 2x MRV-F545's...
how do u plan on setting it up? its all possible, but you must compromise on the TA channels of the HU and 'group' one set together...
ive experimented a little and ended up putting the 4" and tweeter on the same TA channel, and mounting them together...
as for crossovers, set the HU to 3 way mode and go:
Low = Sub = LP (for example, LOW = LP 80hz, 12db)
Mid = 6.5" = BP (for example, MID-LOW = HP 80hz, 12db, MID-HI = LP 400hz, 12db)
Hi = 4" + 1" = HP (for example, HIGH = HP 400hz, 12db)
as an example setup:
* run the low preout to the sub amp (545 rear ch?), amp crossovers off, use HU crossovers (examples above)
* run the mid preout to the mid amp (545 front ch?), amp crossovers off, use HU crossovers (examples above)
* run the hi preout to the 4" + 1" amp (345?), into ch 1 and 2. then flick the 'input selector' switch to 1 and 2 (i think?) which will 'copy' the signal to the rear channels. tweeters off 1 and 2, 4" off 3 and 4. run a HP filter at the amp (eg 3.4khz), at ur desired freq for the tweeters, and a LP (eg. 3.4khz) for the 4", at the amp.
this will give you independant TA control over the sub, 6.5", and the 4" + tweeters together...
with the 4" + tweeters together, they can be TAed together fine (best compromise with the given equipment)...
basically, get the install perfect the first time, and set it up this way for best results (from what ive found)...
ive stuffed up my install the first time with the door pods, and mounting the tweets and 4" seperately (which wasnt a problem at the time, as i didnt have TA) but with TA, and the 4" further back, it drags stage down and back. then combine that with the TA, and the tweeter mounted forward of it, and about 25cm away, TA becomes ur enemy as its hard to get it right, IF at all...
from what ive asked about my install (and the best way to set it up) i was advised to go down that route, and put the 4" and tweet together, as the 4" and tweet would 'generally' be TAed together (or very close together) anyways...
put the 4" and tweeters as far forward as you can get them. in the kicks would be ideal, but now this means that the tweets wil have to go there aswell. unless u have the room to put the 4" and tweeters in the pillars
haha...
