diesel
Jul 27 2007, 01:27 AM
I`m presently running a 9965E H/U with a H701 processor which is connected to the ai-net connection, i also have the kca 420i interface module for the ipod, can i connect this to the processor via the cd changer connection as this appears to be the only other ai-net connection for the ipod to hook up to. I will need to get an extension cable due to the placement of the processor at the rear of the vehicle.
antisven
Jul 27 2007, 07:49 AM
yes there should be a switch under the unit, set it to eq/divide, also you should run toslink to the 701 as its a noisy beast using analogue inputs, you need to use both ai net and the toslink in order to run the radio and have digital inputs into the processor
