I currently have boston pro60's running active off a alpine f545 amp, in the factory door locations for a mitsi galant (station wagon)
the doors are already soundeadned and now air tight just about as well
I have wooden spacers around my boston mids with no air leaks in between
it is only a basic 2 way setup with the sub
DMX is right behind the speaker, in the inner and outer door panel
headunit is a p80rs pioneer, with 3 way active x-over and a 15 band eq
I have taken off time alignment and all other DSP's to test. also the EQ is flat now
I cannot bi amp the speakers with the x-overs as the headunit option will not allow me to, as the high (tweeters) will not allow full range
now it seems the upper frequencies are very loud from the Speaker, and the sound really starts to drop off from 300hz down, as in I cant hear it too well...
I have checked the wiring to see if the speakers were out of phase and they are not.
Have fixed most of the rattles today in the doors, and still nothing
the mids are getting well over 200 wrms each and are rated at 125 w rms.
from experiance with boston pro's, is this normal? I thought the BA mids were very powerful
Could the DMX be causing any of this? should I try a product like Dynamat xorb or whatever it is? firectly behind the speaker?
