G'day ladies and gents of MEA.
Foreword:
Near the beginning of the year I decided that the idea of a fully-fledged computer in a car environment would be a great idea. I set out on a mission to learn about ways and products I needed to implement such a task. I am here today reviewing what I have learnt and the products I have chosen along the way. This will be a comprehensive review of the major components that go into a Car Computer (a.k.a CarPC or Carputer) that I have had direct experience with; I will break up the review into two categories: Hardware Components, and Software components, each specific item I will be going into detail about the reason I chose the product and my experience with them. Accompanying these will be a barrage of photos, so I'm sorry for all those 56k users out there!
The objective of this review is to:
1. Review the products I have purchased on my quest for a CarPC
2. Educate (and hopefully help someone in the future) who is looking into the CarPC environment and share some of the knowledge I have gained along the way.
So let's get started then shall we!
Hardware Components:
There are many products which comprise of a computer in general, some of these components you might be familiar with; others are specific to the CarPC environment. I will be listing all the products I will be reviewing, then taking each one and reviewing them individually.
My CarPC consists of the following hardware components:
- Case: Voom2 Mini-ITX CarPC enclosure
- Power supply: M2-ATX 160w DC-DC powersupply
- Motherboard: Jetway J7F2WE2G Mini-ITX
- CPU: VIA C7 2Ghz
- RAM: 1GB Kingston Value
- HDD: 160GB Samsung 3.5"
- Optical: Pioneer 16x Slimline Slot-loading DVD-RW
- Audio: Creative Audigy 2 NX
- GPS: Globalstat BU-353
- Connectivity: Wifi-Link external USB dongle with 9dbi antenna, Bluetooth USB dongle
- Monitor & Input: Xenarc 700IDT 7" In-dash touchscreen 500NIT brightness
The first item I ordered for this project was the Mini-ITX case and the M2-ATX powersupply (see the following review). Before I get a barrage of questions, let me state where I got these items from, a majority of the items were mainly sourced from the United States, I have a friend over there that deals with the Mini-ITX motherboards and enclosures (for those who don't know what the mini-itx form factor is, it's a motherboard that measures 17x17cm), other hard to source items (and I know these forums don't approve!) were sourced from EBay, the rest were purchased from local computer shops.
The Case enclosure arrived in a pretty non-descript white box but with sufficient padding to keep the case and other items pretty well secured for the trip from the states. The dimensions for the case are: 210(W)mm x 265(L)mm x 66(H)mm. The instruction manual goes through the steps required to put together the system, it was a little confusing at first, but after a few reads and a little common sense everything fits in nice and snugly!
The old adage, a picture tells a thousand words come in handy here so instead of me describing the item, ill just show you!
External (Front View):
External (Rear View):
External (Front View, Faceplate off):
Internal (Top View):
Front RCA Jacks (Front View):
If you follow the manual, putting all the items in is pretty straight forward.
My opinion of the item: The case seems to be really well built, I was quite surprised at the engineering of the case, space was provided for all the items you need to put in, and everything sits in pretty snug. The only gripe I have with this case is that the two little fans at the front of the case (see picture 3), once powered, gets pretty loud! In a car environment I'm pretty sure this will get quite annoying, so for the time being I have left these disconnected and am monitoring the temperatures of the CPU and case from inside windows, if the temp rises too much I will reconnect them. Another nifty feature of the case are the front RCA outputs, basically this is just a header that connects to your motherboard, but instead of providing a 3.5mm jack, it outputs to an RCA. If you're going to be using the onboard Audio, this is a nice feature in that it will allow you to connect to your head unit or amps without the need for a 3.5mm -> RCA converter. The reason I chose this case leaned towards it being specifically built for CarPC purposes.
Power-supply: M2-ATX 160W DC-DC Power-supply
This particular item is one of the most important in a CarPC for a number of reasons; ill try to explain it to the best of my knowledge!
Computers in a home environment have access to 240v AC mains power, in a typical home computer, an ATX power-supply takes this 240v AC and converts it into a number of 'rails' providing constant 12v and 5v DC power for the computer to use (computers essentially run on 12 and 5v DC). Voltage variations on computer hardware is a serious issue, a small voltage fluctuation on these 12v and 5v rails in most cases, causes a computer to reboot or behave in a manner we wouldn't like. Thankfully computer ATX powersupplies have strict regulators, and for this reason provides tight regulation to produce clean, constant power to computer hardware.
In a car environment we run into a serious problem! As most of you will already know, a car essentially runs on 12v (usually varies from 11v-14v) DC, as a majority of normal ATX powersupplies made for computers are built to run on 240v Mains power we have a serious issue. Thankfully as described above, computers essentially run on 12v and 5v DC current, all we need is a power supply that takes this 12v DC car input power and regulates it so it produces a clean, constant 12 and 5v DC.
This is where DC to DC (DC-DC) powersupplies step in, it essentially takes a "dirty" 12v supply (being unregulated and fluctuates between 11-14v, as per a car environment) and cleans the output power so it's suitable for computer hardware components. Anyone who has a semi-serious audio setup in their car knows that when a big low bass note hits, a majority of the time the operating voltage of the car can dip as low as 11 volts, if we used the unregulated power directly from the cars constant 12v, we would have fried computer components (over-voltage, and voltage spikes due to voltage dumps) and constant restarts (under-voltage).
Another reason I chose to use the M2-ATX DC-DC power supply is its smart shut-down controller and its ability to survive engine cranks. When an engine in a car is started, the starter motor draws a lot of current and for those few moments the voltage can drop significantly, the M2-ATX has the ability to function normally when the voltage drops as low as 6v (max 24v). The M2-ATX also has a built in shut-down controller, basically this hooks up to the accessories switched 12v of your car and acts like a remote switch. When the IGN (ignition) of the car is on, the power-supply waits for a pre-defined amount of time before sending the 'on' signal to the motherboard, which in essence starts the computer, the smart stuff comes into play when the IGN is turned off. You have a variety of options (set via Jumpers on the M2-ATX) that specify what to do with the computer once the switched 12v line is set too off (IGN off). These include waiting a specified amount of time before sending the 'off' signal to the motherboard, a Hard-Off time – basically after a user defined amount of time the M2-ATX stops all voltage on the 12v line, and a Traditional PSU mode. The nifty thing with the traditional PSU setting is that the M2-ATX constantly monitors the input voltage and if it dips below 11.2v for more than 1 minute, it cuts all the voltage to all rails in order to stop draining the battery completely.
Okay, your eyes must be exhausted after reading all that, so ill throw up some pictures of the item:
External (Top View):
External (Top View, another shot):
While I'm at it, if you're considering building a CarPC you must take note of the power consumption for each item in the system. The M2-ATX provides a maximum of 160W, when selecting components for the CarPC you should look for low-power consumption items so that the power-supply can provide enough juice without falter.
Here are some general specs of the item:
- Minimum Input voltage 6v, Maximum 24v
- Deep-Discharge shutdown threshold – 11.2v
- Max Output Power – 160W (15A mini-blade fuse)
- Efficiency (Input of 9-16V) - >94%, all rails combined, 50% load
- PCB Size: 160x44mm
- 20-pin ATX Power supply cable
Motherboard: Jetway J7F2WE2G Mini-ITX, CPU: VIA C7 2 GHz and Kingston 1GB Value Ram
Since these items make up the bulk of the performance related items in the CarPC, I will review them all together.
Firstly the Jetway J7F2WE2G Mini-ITX motherboard measures a tiny 17x17cm and has a hard-wired VIA C7 2Ghz CPU attached directly onto the motherboard. With Mini-ITX motherboards, there are two basic paths you can follow, the first being the VIA chip approach, or the second is the new Intel Core Duo (or 2 Duo?) approach. The later is a more expensive but the CPU's are not hardwired and will no-doubt provide superior performance over my chosen VIA path.
Why did I choose VIA then? Well basically my application didn't call for such a fast set-up, I wasn't intending to use the CarPC to play hi-end computer games whilst in the car; rather I was going to use it for GPS, Video, (wank factor
I opted to choose the fastest VIA C7 CPU and Motherboard Combo (the 2 GHz one) which from my observations, is more than adequate for running the applications and computer itself with plenty of headroom for the future.
The Motherboard, being so small has to cut back on some of the features that you commonly find on normal sized ATX boards (e.g. 1 DDR2 Ram slot, 1 IDE port, 1 FDD port, 2x SATA), but it still provides ample amount of integrated peripherals. Onboard Video is provided by the VIA S3/Unicrome chipset, Sound is taken care of with AC'97 5.1 Realtek chipset, S-Video, 10/100 LAN, 6x USB ports (2 included on the back, 2 on the front of the Voom2 Case, 2 more if you can find or fabricate a header for it) and a firewire port are taken care of by the motherboard.
Seeing as the system will only allow 1 Slot for RAM, I opted for 1GB of DDR2 533 MHz Kingston Value ram as this would be more than enough for such a system.
Enough talk, let's see some pictures! Below is a photos of the motherboard in the Voom2 Case
From my observations this setup is more than adequate for the objective I set out to achieve, the system is very responsive, remains relativity cool, consumes very, very little power when compared to Desktop PC's equivalent, which is a bonus seeing power isn't of abundance in a car environment and the more efficient the better!
HDD: 160GB Samsung 3.5" and Optical: Pioneer 16x Slim line Slot-load DVD-RW
Since these two items are only small, I shall review them together. The Samsung HDD was chosen for three reasons: its capacity, its price, and its quietness. With 160GB of hard disk space, it provides me with ample amount of storage to put my Video and Audio libraries along with any other media I choose to put on the CarPC. The Pioneer drive (pictures can be seen from the external case, front view) was chose because I liked the idea of being able to burn any format (DVD-R, CD-R etc) and read the same formats in a car environment. I opted for a Slot-loading drive because it would be too finicky trying to load CD's or DVD's in a practical manner with a non-slot dvd drive. The slot works just like a typical Head-unit that 'eats' the CD, if you can picture what I mean! Both operate as their specifications specify, I have no complaints!
This was an important consideration for me; the onboard sound from a computer isn't anywhere near up to scratch for a sound-quality oriented sound system. I opted to go for the Audigy 2 NX because of a few reasons. Firstly it is their top of the range notebook (in my case CarPC) external sound card, there is a Live! Range, but doesn't possess the same DAC's or output quality of Audigy 2 NX.
Some general specs for the sound-card are as follows:
- 24-bit/96kHz Analog-to-Digital Converter (ADC)
- 24-bit/96kHz Digital-to-Analog Converter (DAC)
- 102dB SNR @ 2vrms
- SPDIF out with up to 24-bit/96kHz
Here's a Picture:
The specs of the sound card seem mighty impressive, basically the output from the soundcard will be going into the AUX-In of my Alpine CDA-9887 which, well I hope, will provide me with much better SQ than the on-board sound.
Ran out of room for the thread, read on to the next post
